Old 01-19-2019, 07:52 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Cyl #1 50F cold 😏
Need ideas, #1 CHT has always been significantly colder. Facts:
1-New 0320x150HP with perfect compression (180 hr)
2-Swap #1 TC with any other cylinder and the cold reading follows #1TC.
3-Replace #1 TC with new Alcor, still cold when flying.
4-Test all 4 TC in boiling water it reads 212F.
5-Used one TC in boiling water applied to all 4 panel inputs. All read 212F.
6-Installed a little deflector on #1 like #2 has from Vans baffle plans, no joy.
My concern with blocking #1 more radically to get a response is “What if the above is somehow flawed. Don’t want to cook a cylinder.
I noticed a Dave Anders pic with #1 cyl wrapped nearly to the top af the fins. OK, but why isn’t everyones #1 grossly colder ?
Ideas appreciated...Larry
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-19-2019, 09:27 AM
Check the bottom air outlet on the cylinder and compare with the others. A larger opening can be closed using
small inserts or even a bit of rtv for test purposes
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 01-19-2019, 12:05 PM
BillL BillL is offline
Default Excellent thought +1
Originally Posted by Tom Martin View Post
Check the bottom outlet on the cylinder and compare with the overs. A larger opening ca be closed useind small inserts or even a bit of rtv for test purposes
After checking absolutely everything else on my engine, I am pretty sure this is my issue for #4 running a tad hotter. I measure my opening and it is maybe 1/8" smaller yielding 20F hotter under nearly all conditions. I was very careful about the gaps and this one must have been on the small side.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 01-20-2019, 06:42 AM
Default Small opening ?
Thanks guys, great catch. I assume the small opening is the curved baffle under the cylinders connected by wire/bolt/ or spring to pull them together ??
Larry DeCamp
Clinton, IN
Old 01-20-2019, 06:58 AM
Default Under the HEAD
It is the opening under the HEAD not the cylinder/barrel that will affect CHT. My data indicates barrel opening will not affect your CHT.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Shrunken Exit = ??
No Photo? => PM me.
Old 01-21-2019, 02:48 PM
odens_14 odens_14 is offline
Am i interpreting the quoted statement correctly: it's always the #1 thermocouple(TC) reading cool, even when that TC is connected to another cylinder?
if that's correct, it cant be anything with the baffling. You've replaced the TC with no change that tells me it must be the instrument itself? the fact they all read correctly in boiling water indicates it must be caused by the engine running, vibrating loose connection or something electrical possibly?
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 01-21-2019, 04:22 PM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Fuel/air mixture is a strong driver of cht, and it is different for each cylinder. Have you done the cht/egt vs fuel flow curves? Run it at whatever power you are reporting the 50F lower, only go from quite rich (maybe 2-3 gph richer than where you run) to lean enough where it is running rough and losing noticeable power. Pause at every .1 or .2 gph to allow temps to stabilize perhaps 30s. Your cht variation might not be air cooling related, but simply where cylinder one reaches peak cht at a different point than the others.
Think about your engine as four separate engines, each developing a bit different hp, and each running a different fuel/air ratio.
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
