Pretty sure I already know the answer to this but I want to probe the A&P/AIs out there on this...
This is for part FL-406A ( RV-8), which is fabricated from AA6 125 11/2x2 airgrade grade angle. This is part of the fortification and installation of the flap piece that is actually connected to the extension rod. With airloads and such on the flap, I would imagine there is a lot of stress in this area of the flap.
Since I cannot locate my original piece to do this, I either need to procure another piece either from Vans or another aircraft parts supplier, or run over to Home Depot and but some similarly sized angle and move on..
The difference I see from the good stuff and the HD variety is the inclusion of an inner radius on the aircraft grade, whereas the HD angle does not! Also, not sure if the manufacturing process of the HD version would be of the same standard as aircraft grade. This appears to my amateur thinking as a potential weak spot for cracking and coming apart at a later date thus possibly rendering one with an assymmetric flap condition and an interesting landing.
Am I on the right track here to be suspicious of the HD variety for this particular application, or does it really matter??
Thots?
Thots?
