s10sakota
I'm wondering if this is normal? I can not untwist the twist in the tank ribs. I have fluted them, and if I lay it down on the bench, one corner of the rib will pop up. I can press down with a finger on each corner and it will lay flat against the bench, but as soon as I lift a finger, a corner will pop up.
No matter what I do with the fluting, there is still a twist in the rib. Does this matter? With much moaning, groaning, and swearing, I am able to cleco them to the tank skin. I suppose the skin holds them without the twist, but I just want to make sure this is ok because right now I'm ready to take a sledge hammer to the **** thing.
