Go Back   VAF Forums > RV Firewall Forward Section > Propellers
View Poll Results: What do you use on your airplane?
a short (3” or less) prop spacer 8 25.00%
a short (3” or less) prop extension 8 25.00%
a long (more than 3”) prop spacer 2 6.25%
a long (more than 3”) prop extension 12 37.50%
something else (if that’s possible) 2 6.25%
Voters: 32. You may not vote on this poll
Old 11-30-2017, 11:48 AM
humptybump's Avatar
Default Prop Spacer or Prop Extension - survey
I was recently told that the long bolts required for using a 2-1/4” propeller spacer were getting hard to purchase and there are advantages to a using a prop extension. (I had no problem with a recent order of new bolds from Vans Aircraft.)
Thought I’d do two things to help those in the process of building or modifying their airplane.
First, do a quick survey. Second, give contributors an opportunity to post their opinion/experience on the subject.
- Glen, ESVA
Old 11-30-2017, 11:59 AM
humptybump's Avatar
Oops.
If a moderator could correct the title please. It should read:
“Prop Spacer or Prop Extension - Survey”
This will help current and future readers and searches.
Thanks.
- Glen, ESVA
Old 11-30-2017, 01:00 PM
Raymo's Avatar
Raymo Raymo is offline
Using the James long cowl required a 4" extension from Saber, who also supplied the bolts. This extension does not require super long bolts. The extension bolts to the flange and the prop to the extension.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 11-30-2017, 10:33 PM
Who recently told you that?
I have not heard about any difficulties.
If it were true, it would pretty much put Sensenich out the metal RV prop business because there attachment is designed around the use of long bolts.
Also, I see a negative value in using a hub style if installing a wood/composite prop. With the lighter propellers, also using a lighter extension/hub can be a detriment in regards to aircraft utility because of the negative influence on C.G. position.
Scott McDaniels
Hubbard, Oregon
Old 12-01-2017, 09:31 PM
maus92 maus92 is offline
I had to replace 3 prop bolts recently. I tried to buy them from Saber (because they were significantly cheaper,) but they were having difficulty getting the proper length from their supplier. I ended up buying them from Sensenich.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 12-02-2017, 09:45 PM
1bigdog 1bigdog is offline
Default prop extension, from the source
Vans was very clear on this topic when I asked them very recently, as I was placing a Catto prop on an IO-320 on their cowl:
"Regardless of the engine/cowling combination the propeller extention for a fixed pitch prop will be the same 2.25"
Cheers.
Michael B.
C-FWMB (reserved)
College Fund Contributor
Old 12-02-2017, 10:08 PM
Mel's Avatar
Mel Mel is offline
Default Not Quite all...........
Cheers.
Fixed pitch cowlings supplied before the mid '90s all used a 4" extension.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-04-2017, 08:21 AM
Default No problem.
We have found no problem in getting parts. We use a 2 1/4" spacer for a Prince prop. We did buy the spacer and bolts from Saber for both the spacer to engine and the prop to spacer make-up. Van's had them as well, but we just did the old one stop shopping thing to save on shipping at the time.
Hope this helps your question. Yours, R.E.A. III # 80888
Old 12-04-2017, 10:36 AM
humptybump's Avatar
If you have one set of bolts connecting an aluminum section to the engine flange and then a separate set of bolts from the aluminum section to the propeller, this is what I was calling an “extension”.
The spacer has thru-holes and requires bolts long enough to pass through the crush plate, propeller, spacer, and thread into the engine flange. For a 2-1/4” spacer, these bolts are typically more than 8” long.
- Glen, ESVA
Old 12-05-2017, 08:03 AM
Glen, when you put a 3 1/2'" thick wood prop, a 3/4" crush-plate, spinner bulkheads, and washers into the stack-up, the bolts or long as you ask.
I would have to size them again after all these years, but they are at least 7-8 inches long. Thanks for you clearing up what an extension is.
Hope this helps, Yours, R.E.A. III # 80888
