Three antennas, four antenna wires, one telephone wire and two snap bushings?
Well I am starting the wiring and my plans (rev 3) show three openings for the antenna in the forward center bottom of the instrument bay. My plane only has two openings in the forward centerline of the instrument bay, one larger than the other.
There are three antenna cables: the WH00051-1 com antenna, the WH00050 transponder antenna and the WH00095 ADS-B antenna and only two snap bushings in my plane. To further confuse matters, the drawing shows a split in the WH00050 with two legs, each leg going into two of the openings for a total of four antenna wires.
I am a bit confused.
Jeff
Jeff
