Wiring gurus
rwarre
Adding a 2nd Pmag. Used the AEC Z-11 for a template. Want to know if I can use the power wire on terminal 4 of the Left mag switch that goes to the starter to also power whay will be the 2nd pmag. I would be connecting two wires to the same terminal.
Aeroelectric list
I recommend posting this question to the Aeroelectric list. Bob Nuckolls will probably respond.
The question is a little bit confusing. Terminal 4 is a p-lead, and you certainly need to wire them separately, just like for normal magnetos. Terminal 5 is +12V power terminal and they should also be wires separately via individual switchable circuit breakers, according to the manual.
