I note that Spruce carries positech coolers, and they're considerably less expensive than even the Van's coolers. I've read numerous reports on here that their performance is underwhelming
Aero Classic coolers are nearly as inexpensive to buy as the Positechs, and IMHO have the cooling efficiency slightly better than NDM (stock Vans), but not as good as the super-expensive SW cooler. They are drawn cup design, just like the NDMs, and seem to be a very good value in an oil cooler. You can get them in 7, 9, 10 and 13 row sizes for the $250-300 price range. Spruce sells them, and you can also get them from the source... PacificOilCoolers.com. Aero Classic is also now making some new SW-style copies as well, for significant savings over the SW/Meggitt prices.
Good info Neal, thanks!
Are the Aero Classic SW clones bar and plate?
There are previous posts with pictures if you search back, but I used Van's bigger 13-row cooler, mounted to the firewall on a plenum box similar to what Van sells for the RV-10, but the angle was adjusted to match the angle of my engine mount.
It is supplied with a 3.5" scat tube off of the back of baffle for cylinder #3. I have a throttle plate/butterfly valve in the flange connection at the baffle, for cockpit-adjustable cooler flow control.
Works great.
