Hi All,
I'm about to install my wing root fairings (F-799), and was just checking edge distances on the tank skins (T-701). It appears I have 15.5/32" of tank skin to play with before it butts up against the tank rib, but if a k1100-08 nut plate is 13/32" wide, then that means my hole centerline only has a 9/32 edge distance. In addition, this short distance (13/64) between the hole centerline and the tank flange means the make die will riding up on the tank rib flange, giving me an ugly dimple. There seems to be little addressing this in people's websites or the forum. How are people dealing with this? Are you guys making a shim the same thickness as the tank rib flange for the dimple die to ride up on, then just putting up with this lousy edge distance, or are you switching over to NAS514P-6 screws and just using twice as many so this edge distance is ok? Or something else? Words can not explain how frustrated I am with the edge distances in this kit. If they are that mad keen on saving weight, make me cut another lightening hole somewhere, but quit giving me lousy edge distances to work with.
Tom.
Tom.
