Stockmanreef
A couple questions:
1. Does the fuel line flare fitting get any tank sealant? The reason that I ask the question is that at the bottom of the page in bold it says "Double check that the vent line is clear and has not become clogged with sealant." How would sealant get into the line if it was not put on the connection between the aluminum tube flare and the fitting.
2. How does one torque down the fitting with a torque wrench? The only way I can figure it out is to go to HD and buy the correct size open ended wrench to fit on the torque wrench, since a socket won't work.
3. Should I cover the vent line bulkhead union fitting, nut, and tubing with sealant to ensure that not leaks will occur?
Ken
Ken
