Old 04-02-2017, 08:24 AM
Cwood2000 Cwood2000 is offline
Default Bell Crank Jig W-730
On page 23-09 the plans call for a W-730 Bell Crank Jig to set the neutral position of the Bell Crank. I can't find one in any parts list nor a plan on making one. Did I miss something?
Aka YellaDawg
RV4
RV14 in gestation
Old 04-02-2017, 08:43 AM
wirejock's Avatar
wirejock wirejock is offline
Default Jig
It wasn't in my 7a kit either. Buy two. They are handy to lock both wing/ailerons for storage.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-02-2017, 08:53 AM
control control is offline
It was in my kit. look at the picture, it is a flat piece of thicker aluminium. It is in the inventory sheet, not sure where as I primary use the one shared on Google drive.
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 04-02-2017, 10:36 AM
JHartline JHartline is offline
Default Section 4 shows it in the wing kit
Mine was in the wing kit. That's also where the master inventory in section 4 has it listed. Listed as W-00730 2024-T3 ALCLAD SHEET. Sometimes the leading zeros matter...
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 04-02-2017, 12:35 PM
No Joy, Mine is a early wing kit and its not on the packing list. I see it in section 4 but not on my packing slip or hardware sheet. Was it listed in a SubKit? In any case I'll get two from Van's I surely don't have one.
Thanks for helping out and securing my sanity.
YellaDawg
Aka YellaDawg
RV4
RV14 in gestation
Old 04-02-2017, 03:03 PM
czechsix's Avatar
czechsix czechsix is offline
Same here, I have wing kit #140017 and the aileron jig was not in the kit. I called Vans and figured they'd just drop one in the mail for me, but they said I'd have to buy it. It's a cheap part but silly nonetheless to charge the customer for something that was clearly supposed to be included in the kit from the outset...
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 04-02-2017, 09:34 PM
JDA_BTR JDA_BTR is offline
The important question - will you prime it? It has to last for the life of the plane because it is the master alignment jig.....
N1463 seems a good number....
Old 04-03-2017, 10:22 AM
Logan Logan is offline
Default Got one in my kit
I got the part in my QB wing kit, delivered a few weeks ago. Looks like they are now including them in kits.
JDA_BTR, a n00b question for you: Should I expect to use this jig in future regularly or is this an emergency, rebuild-type need? Thanks!
Logan
Logan Dent
RV-14A in progress
Empennage complete(-ish)
QB wings and Fuse in progress
Old 04-03-2017, 11:39 AM
wirejock's Avatar
Default Jig
Logan
It's used to set the neutral position of the ailerons during any rigging.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-03-2017, 01:45 PM
Bill Dicus Bill Dicus is offline
Default Jig
One was included with my (older) RV-8 QB kit. Ordered a second which was handy for the rigging of ailerons. It would be an easy part to miss or mislay!
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
