Hi,
A great hangar (36'x44') came up locally last month and I was lucky enough to purchase it. I'm now in the process of setting it up to finish my build and for year round use. I'd like to add a small mezzanine above the work area (12'x16') which will impact the floor layout slightly. I'd like to squeeze a second aircraft in to help with the running costs. I figure a high wing Cessna (170/172/182) would work if it's wing clears the RV14's cowl.
My question is does anyone have the height of the 14A cowling top? Also the distance from the underside of a Cessna wing to the floor? Also is there anything else I should consider with this setup?
Thanks Jim
Thanks Jim
