Old 11-04-2018, 08:39 AM
gasman gasman is offline
There is an app for that...... A good one is Clinometer + bubble level by plaincode.
VAF #897
2019 =VAF= Dues PAID
Old 11-04-2018, 09:04 AM
larosta larosta is offline
You may need to check the calibration of your bubble level. A web search for “how to calibrate a spirit level” should return several written and video procedures. If your level is out of calibration and Unless your level is a expensive engineers machinists level you will probably just want to replace it.
-larosta
Old 11-04-2018, 11:37 AM
joedallas's Avatar
joedallas joedallas is offline
Default Level
Set the level on any close to level surface and mark the location of the level.
Rotate the level 90° in the same location and the bubble should be in the exact location it was in the first test, if it is the level is ok.
A easy test the level hold the level on the wall with the bubble between the lines then draw a line on the wall.
Rotate the level 90° and check the line, if it is not level then draw a new line with one end on the first line.
Level is a line in the center of the distance between the two lines drawn.
A good idea if you are married put a piece of paper or removable tape on the wall first.
Joe Dallas
-larosta
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 11-04-2018, 12:22 PM
Excellent...
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 11-04-2018, 12:27 PM
tomkk's Avatar
tomkk tomkk is offline
Originally Posted by AirHound View Post
Hi Tom, Yes. Bubble is off to the right when calibrated/digital reads 0.0. How can that be?
Is the bubble an actual spirit level? My digital level has a bubble but it's just an electronic picture of the digital readout, not a spirit level that's independent of the digital value. If my bubble was different than the digital readout I'd figure it was defective.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 11-04-2018, 01:14 PM
Most digital levels have a calibration function.
If your bubble turns out to be accurate but the digital value is not, perhaps you accidentally recalibrated when it wasn’t actually level.
Scott McDaniels
Hubbard, Oregon
Old 11-04-2018, 05:23 PM
AirHound AirHound is offline
Scott,
I’m fairly confident I have her set at 71.4 w/i .1.
Say, is it possible at 71.4 to get a high MP alert on climb out and it goes away at initial cruise?
Doug
Doug
Old 11-04-2018, 07:02 PM
hook hook is offline
Scott,
Doug
The few in our fleet do this regularly.
RV-12 Owner & Flight School Operator
CFI/CFII/MEI
LSRM-A
chris@flygcaa.com
Old 11-04-2018, 07:50 PM
Default Any info/historical facts on Effects of high MAP an ROTAX 912s
With respect to MAP, I know what overboosting an C/S prop’d engine is and what it can lead to rather quickly. Any stories out there about effects on fixed pitched ROTAXs? Any more info out there other than it should be avoided..? If 27.5” is high on the meter, then is there a too high number for short durations like climb out?
Doug
Old 11-04-2018, 08:19 PM
DHeal DHeal is offline
See: https://legacy.rotaxowner.com/si_tb_...912-016-r1.pdf
That is ROTAX's Service Letter SL-912-016R1.
Section 3.1.3 pertains to MP and appropriate operating limits.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 740+ hours (as of Mar 2019)!
VAF donation through June 2019.
