XP-360 with about 300 hours, EIS 4000 monitor. Oil pressure has always run around 80 psi. Day before yesterday it was steady at 92, yesterday was fluctuating between 96 and 99. All other parameters were completely normal, including oil temperature which was 170 degrees. The engine was running perfectly. Verified the pressure indication dropped to zero at shutdown.
Can anyone think of anything OTHER than a sensor/instrument problem that would cause this? Should I be worried?
Thanks!
Thanks!
