kevinh
Hi ya'll,
I'd like to request diagnostic assistance:
I'm on the way to OSH and noticed an odd thing: normally my master bus voltage is 13.6. However, on the last leg of my flight it dropped to 13.2 and then 12.9. I was like 'uh oh' - I have an ebus, but wasn't looking forward to swapping alts at OSH.
So I started turning things off. As soon as I turned off the autopilot servos, it went back up to 13.6 (yay! alternator working again). Later in the flight it started to creep down to 13.4. Then I turned off strobes and it went back up to 13.6.
So, is my alternator dying? I'm thinking it is unlikely a connections problem because lowering the draw allows the current to stay up. (Also, if you are thinking this is due to the ~.6V drop from the e-bus diode, my voltage is measured from the master fuse bus)
