Old 10-16-2019, 05:55 PM
jakej jakej is offline
FWIW it may help to mention blast tube diameter - I use 3/4” inside diameter & no issues with cooling in 550+ hrs to date
Old 10-16-2019, 06:59 PM
N941WR's Avatar
N941WR N941WR is offline
Alain,
I had forgotten about this thread until this evening.
http://www.vansairforce.com/communit...ad.php?t=88012
Take a look at post #8 on the first page and post #12 on the second page. (I can't remember how to point you directly to those posts.)
They highlight the temperature rise and fall after engine shutdown.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-19-2019, 07:23 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Originally Posted by N941WR View Post
I agree, it sounds like the internal generator has failed.
As for the temperature issue, most high temperatures are recorded after the engine is shutdown and the aircraft is parked, say for fueling.
You can add additional thermal stickers to see what temperatures you are dealing with.
That or install an EICommander, which can report the maximum and current temperatures.
Remember, the blast tubes are supposed to be aimed at the neck of the P-mags, not the rectangular section.
I'm thinking to install some kind of temp probes in the engine compartment to monitor the temps in the cowling.
Blast tubes are 3/4", and are directed at the round part, as recommended by Emagair
Alain,
Thanks for that, I had a look ans some interesting posts there, specially the ones talking about hooking up a temp sensor to the Dynon Skyview
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
