  #31
Old 08-02-2018, 02:42 PM
David Paule David Paule is online now
Email sent to Joe.
Old 08-02-2018, 08:27 PM
EXflyer EXflyer is offline
Default OK?
So still no radius at the end of the threads and the threads are still sharp in the root. Every one on here worries about stress risers in scratches which are the same. Not putting down your design just saying that its a stress point when side loaded.
Old 08-02-2018, 09:14 PM
AirHound AirHound is offline
Originally Posted by RFSchaller View Post
Doug,
The older fiberglass epoxies lost strength if overheated. The critical temp was called glass transition temperature, and 30 years ago people tried to avoid painting dark colors on the fiberglass so it wouldn’t sit in the sun and lose strength. In Phoenix we can actually fry an egg on a dark surface on the worst summer days. GTT was something you had to think about.
Thank you!
Doug
Old 08-03-2018, 11:02 AM
joedallas's Avatar
joedallas joedallas is offline
Default Tie Down
With the angle less than 60° and the bolt is in a counter bore I can't see the loads needed to shear the 3/8" 2024 T3 Aluminum with a shock load from a tie down rope.
Also my aircraft is in a hanger 90% of the time.
I feel comfortable with this design.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 08-03-2018, 11:54 AM
Default Interesting Observation...
This thread ponders the the all-important question "Flying with or without wing tie down rings" and has 3,213 views and 33 replies.
The thread titled "Official Sensenich Propeller FAQ/Service Bulletin Revision B" only garnered 1,043 views and 6 replies.
Aren't folks worried about their props falling off?
Maybe its just the times we're living in...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 419
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 08-03-2018, 03:25 PM
rv9builder rv9builder is offline
All RVs have tiedown rings. Only RV-12s are affected by the prop service bulletin. That's probably the reason for the higher number of views on this thread.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 08-03-2018, 09:19 PM
The prop issue has some authoritative discussion from the manufacturer and an SB, while the tie down ring issue is open to discussion without conclusive evidence. That probably lends itself to more discussion.
Old 08-05-2018, 06:00 PM
DaveWelch DaveWelch is offline
Hi Joe,
We all fully understand your focus to finish and look forward to seeing your finished airplane!
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
