Old 07-29-2018, 07:03 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Flying with or without wing tie down rings
A quick question to all flying RV-12 drivers. Do you fly with the wing tie down rings attached, or do you always remove them before flying?
What is best practice here?
Thanks a lot
Chris
Chris, RV-12 HB-YSC
Phase I
Facebook: http://www.facebook.com/magic.carpet.aviation
12-Town:http://12town.com/profile/Chris
=VAF= dues paid for 2019
Old 07-29-2018, 07:32 AM
rgmwa rgmwa is online now
I remove them. Probably not much chance that they would work loose and fall out but why risk it? Less drag too, although it wouldn't be noticeable. Should add that I don't often use them as my plane is nearly always hangared.
rgmwa
120346
Old 07-29-2018, 07:52 AM
DaleB's Avatar
DaleB DaleB is offline
I only tie down on rare occasions, so I install when needed and normally have them in the glove box. So far, in fact, I think I've only used them at Oshkosh. The rest of the time I just chock the nose wheel. I'm generally never parked outside fo the hangar for more than a few hours.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-29-2018, 08:19 AM
n74846 n74846 is offline
I'm one of the unlucky hangerless owners in SoFla. and tie down. I never remove for flight and do not see airspeed reduction or risk of loss in flight.
Steve at BCT
Flying a built ELSA
Old 07-29-2018, 08:24 AM
snopercod's Avatar
Once I forgot to remove them and accidentally flew several hundred miles in my Lancair with them hanging down in the breeze. I didn't notice any difference in performance, but did add "Check tiedown rings removed" to my preflight checklist.
(2019 dues paid)
Old 07-29-2018, 02:13 PM
I only remove mine at annual when I install hex head bolts as jack points to jack up one wing at a time for wheel and brake maintenance. I bought a tall hydraulic jack from Nortern Hydraulics and machined a cup on one end of a 2 OD AL bar for the jacking bolt hex head. I bored the other end of the bar to slip over the end of the hydraulic jack shaft. The AL bar is about 4 long. Works great.
Old 07-29-2018, 04:42 PM
N941WR's Avatar
N941WR N941WR is offline
Remove the steel rings from the aluminum fittings.
That would be a hint.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-30-2018, 08:15 AM
benfra benfra is offline
Thumbs up tie down rings
Good Hint! Yes electralisis still exists!
Old 07-30-2018, 10:06 AM
Would that include all bolts in the airplane?😜
Old 07-30-2018, 10:16 AM
Default And...
Yep, better remove any dissimilar junctions throughout the airplane!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
