Old 04-23-2018, 09:11 PM
YoVuelo YoVuelo is offline
Default Map Box... or not
I am working on Section 35 and am not planning on installing a map box. Would it be wise to just cover the hole in the sub panel with a blank panel so that area would be available for mounting other avionics, etc? I just want to make sure I'm not missing some other good reason there is a nicely framed hole placed here...
YoVuelo-Tucson, AZ
RV-14A Kit 294
Empennage Started 5/23/16 - Comp. except fiberglass
Wings - 95%
Fuse - 98%
Old 04-24-2018, 01:43 AM
control control is offline
I say do nothing until you know what you want there.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 04-24-2018, 06:33 AM
mturnerb mturnerb is offline
No map box planned. I like having access through the sub panel hole. If I mount avionics there will probably just make a bracket and add some nut plates to hold it. That way will still have the hole for future access if needed.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 04-24-2018, 09:28 AM
KeithB KeithB is offline
I did as you are proposing - put a plate over the hole allowing more surface for mounting avionics.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >375 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 04-24-2018, 09:46 AM
Nova RV Nova RV is offline
Plate over the hole and mounted avionics boxes. Some people have made bracketing that holds the boxes through the hole horizontally as well. Unless you are going to cut the map box hole in the front panel, don't rivet in that lip now at the very least.
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 04-24-2018, 11:28 AM
I've got a non-RV and have owned it for decades. It has a glove box in the panel, and that's a very handy place for small storage. I won't say that I couldn't fly without it, but it would be harder.
It's held in with two #8 screws per side, accessible from the panel. The box comes out by dropping down under the panel, giving the sort of access we all like to have.
In my opinion, it would be a mistake to leave the glove box out if you have the option of installing one.
Old 04-24-2018, 12:06 PM
pa38112 pa38112 is offline
I agree. You won't be putting a map in there, but it is a great place for batteries, pens, sump tester, sun shade, CD's, O2 Pulse meter, adapter and charging cords, etc., etc., etc.. If you have no current plan for the space, why not have a map box? You can remove it later if you need panel space.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 04-24-2018, 06:05 PM
rzbill's Avatar
rzbill rzbill is offline
I custom built a glove box since I had aluminum sheet left over from an OOPs during construction. I don't miss the panel space and that box is soooo handy. Wondered about that during construction. Glad I built it. IE. Sump tool, batteries for headsets, oximeter, barf bag, Sunglass cleaner, POH for anybody that cares and wants to dig for it, etc.
EDIT. Added pic from construction log
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 04-24-2018, 06:42 PM
revenson's Avatar
revenson revenson is offline
Yes. Use a map box. RV'S don't have much storage space.
Roger, 7A, N374RS, Tucson
Old 04-24-2018, 07:24 PM
Ralph Inkster Ralph Inkster is offline
Map box- I donít use it, but my wife loves it. I actually had to make an oversized one for her.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
