Old 03-16-2018, 10:23 PM
asw20c asw20c is offline
Default Wing Stand
Given that I'm still traumatized by my disastrous first-foray into using fuel tank sealant last weekend I've been putting off my next attempt, but trying to remain productive. So, since I was going to have to do it sometime I decided to go ahead and build my wing stand. I modified the EAA design so that the same wingstand could be used with or without the fuel tanks installed and added some additional cross bracing cables. Other than measuring where the saddles should go, I pretty much made it up as I went. Not sure how things are in other parts of the country but here in New Mexico it seems it is impossible to buy lumber that isn't split, twisted, or warped which makes projects like this harder than they should be. Anyway, I'm pleased with how it turned out even with the **** lumber. I'll try adding a photo:
Empennage Complete Except for Tips
Wings Underway
Old 03-17-2018, 09:32 AM
SabreFlyr SabreFlyr is offline
Sorry, Clay. No pictures.
Ray Dosh
LJ45 driver
RV-14 QB #140212
VS, rudder & elevators finished
HS started
2018 DUES PAID
Marion, IN MZZ
Old 03-17-2018, 04:17 PM
Hmmmm. Not sure why you can't see them. They're there when I open the post so I don't know how to fix the problem. Sorry.
Wings Underway
Old 03-17-2018, 05:18 PM
czechsix's Avatar
czechsix czechsix is offline
I have tried to post pictures on VAF before with links to my Google Photos account (putting the pics in a folder that can be publicly shared). Sometimes it has worked, other times I'm the only one who can see them. Sure wish in 2018 there was a simple way to reliably put pictures on this forum....If I had a dollar for every time I've seen people having issues with this, I could pay for a new IO-390. The Beechtalk forums have a much easier way that just works well...
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 03-17-2018, 10:47 PM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
A big part of that is the version of vBulletin this board runs. It looks to be a very, very old version at 3.6.8. Which was released 11 years ago, in 2007. vBulletin stopped supporting this version nearly 6 years ago, around 2011-2012 range.
The newer versions of vBulletin support drag-and-drop photos in posts, and have way more features for creating posts.
If you're looking for a good photo hosting site, which makes it easy to put photos in this archaic version of vBulletin that VAF uses, give www.imgur.com a shot.
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
VAF Donation paid for 2017
Old 03-18-2018, 03:52 AM
TASEsq TASEsq is offline
The trick to google photos, is you cannot use the google "share photo" function - this merely copies a link to the album where the photos are stored, not the actual photo. You need to click on the photo to view it in google photos, then right click and select "open image in new tab". Then copy the whole URL and place it in the post using the "IMG" tag.
If it works you should be able to see a photo here? (Please advise?)
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Dues paid until April 2019
Old 03-18-2018, 04:39 AM
TShort TShort is offline
I see a photo (bench sander)
Thomas Short
KUMP - Indianapolis, IN
RV-10 N316JS bought / flying
RV-8 wings / fuse in progress ... still
N329TS (had it, lost it, looking for new number)
Old 03-18-2018, 05:58 AM
Hurrah! Itís too good to be true!
___________
Trent Stewart
Old 03-18-2018, 07:08 AM
Mudfly Mudfly is offline
I think it's been mentioned here before, but I just tried tinypic.com the other day as a test and it worked great. No account needed and it's very easy.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 03-18-2018, 10:34 AM
rv9builder rv9builder is offline
Not sure how things are in other parts of the country but here in New Mexico it seems it is impossible to buy lumber that isn't split, twisted, or warped.
I had the same problem in Southern California when I built my workbench a few years ago. The wood I found at a lumber yard was better than the stuff at the big-box stores, but it still wasn't very good.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
