Old 12-02-2017, 08:08 PM
czechsix's Avatar
czechsix czechsix is offline
Default EarthX battery fit in RV-14 battery box?
Does anyone know if the EarthX battery will fit in the battery box that comes with the RV-14? The EarthX is just slightly bigger than the PC680 and won't fit in some of the battery boxes designed for the Odyssey. One of the EarthX reps working the booth at OSH this past summer told me their battery will fit in the RV-14 battery box so I'm wondering if anyone has tried it to confirm?
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 12-02-2017, 09:02 PM
SabreFlyr SabreFlyr is offline
I can't say with any certainty but I measured the battery box on my QB -14 fuse and it isn't thick enough for even the 680C. I'm planning on replacing my box with one that will hold the 680 (I actually plan to have two if I can find the space). Haven't decided whether I can be comfortable with the aluminum boxes from EarthX or if I'll try to fabricate one in SS.
Ray Dosh
LJ45 driver
RV-14 QB #140212
VS, rudder & elevators finished
HS started
2018 DUES PAID
Marion, IN MZZ
Old 12-02-2017, 10:27 PM
czechsix's Avatar
If you're trying to fit an EarthX battery into an Odyssey PC680 battery box you'd probably want to use the 3.1" thick ETX680. The ETX680C is deeper at 3.4".
Mark Navratil
Spring Hill, KS
Old 12-04-2017, 08:40 PM
I forgot which one was thicker but, from my measurements, neither will fit.
Ray Dosh
LJ45 driver
RV-14 QB #140212
HS started
2018 DUES PAID
Marion, IN MZZ
