Baffling question...
kbalch
I'm working on my engine baffles and have a question about 47-06, Figure 2:
  • To which side of the engine case are the two brackets attached (right side or left side under the fuel injector brackets)?
The drawing isn't as clear as I'd like on this point and I've convinced myself that each is correct, so I figured that I'd query the group before having to redo it later. :rolleyes:
Thanks!
Well, I figured it out. :)
The brackets go on the right side, which is the only place where the aft center bracket can fit, given that its nutplates have to be in position for the aft baffles.
Onward!
