Old 07-05-2018, 06:38 AM
Electrogunner Electrogunner is offline
Default Show planes cowl
I'm getting ready to hang the engine and work the baffling and cowl. What modifications need to be done to the vans supplied baffling for the SP cowl at the inlets? I'm trying to avoid doing things twice.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 07-05-2018, 06:49 AM
mgregory176 mgregory176 is offline
Default Showplanes cowl
The rear of the baffling can be set up as stock. The intake plenum from Showplanes needs to be set up to the cowl inlets then the baffling ramps will be set to the plenum.
Mike Gregory RV-10
Working on the fuselage
Clayton, DE
http://www.mykitlog.com/mgregory176
I'm better at building than updating the website
Old 07-05-2018, 09:12 AM
Default Spacer
Anyone have the flyboys cowling install spacer tool they would like to rent or sell?
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
Old 07-05-2018, 09:19 AM
Jpm757 Jpm757 is offline
Flyboys rents the tool for $100/mo., It worked great for my cowling installation, even though I didn't have my prop yet due to long MT delivery times. I used the measurements from the MT drawings. Made the job (almost) painless.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 250+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 07-05-2018, 10:46 AM
Default cowling
I used a router and trammel to cut a piece of MDF the size of the spinner back plate. Then I used 1/2" ID nylon spacers from the hardware store to locate the disk at the correct distance from the prop flange.
Does the same thing as the jig that they rent. The problem with the jig, when I was doing this, was that it was for Van's 13" spinner...the Showplanes cowl requires a 15" spinner. (I used an MT prop and the spinner blueprint says the actual spinner is slightly less that 15". I called Showplanes to verify)
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 07-05-2018, 10:49 AM
I have one I've been planning to sell. Send me a PM if interested.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
