Torque Tube Parts
JDA_BTR
On page 23-06 it says to make two CS-00009B torque tube collars by cutting WD-1014PC into two pieces. The only option I have left on my part shelf is a two foot long piece of black pipe; it has no label sticker on it; but it does fit inside the torque tube subassemblies. Is that the WD-1014PC? Just making sure before I cut it up......
My inventory sheet says I should have two WD-1014PC, and looking at the powder coated pieces I do indeed have two; the arms that the plans call WD-1014 (no PC in the plan). So I think the inventory sheet says I have two WD-1014, and makes no mention elsewhere of the black pipe that seems the right thing to use as WD-1014PC in the plans.
Further up in the inventory sheet I find ST4130-035x7/8x22, "WD-1014C makes two".
So here is final correction:
Inventory Plans
WD-1014C (1) WD-1014PC (makes two CS-00009B)
WD-1014PC (2) WD-1014
