Scott, since the -14 comes with the inline filter does that mean there will be no gascolator in the FWF kit? I looked back at my pictures of the RV-14 from Oshkosh and can't see a gascolator drain protruding through the cowl anywhere...
On some RV's the wing root, allows space for one andair gascolator per side, with the use of flex lines. This provides a cool location, with ease of sampling prior to flight. Also on the plus side is that either unit could block and allow you to feed from the other tank. Somebody more gifted than I with searching can find the threads and photos of some of the wing root gascolator installs.
