Aileron Travel
Zazoos
Working on up and down travel limits of the left aileron.
Down is fine, but up is not getting the minimum travel prior to interference.
Picture for clarity. As always I appreciate the help.
Did you have washer installed under the bolt head? That would certainly interfere with the travel?
Well this seems to be a case of builder fatigue!
I forgot about the necessity to place the aileron in the trailing position and either zero my digital angle finder subtract the negative number. I was just placing the aileron in the up position and sticking the angle finder on it.
In trail it is 7.5 degree negative so now I get 29.5 up with bolt in place.
Thanks to Vans Support for my pointing out my oversight.
Time to go to a movie!
Thanks again,
