Old 05-18-2017, 02:44 PM
meyer228 meyer228 is offline
Default FS 2x O-320 out of a twin 1965 Apache
I don't have a lot of information on these (listing for a friend) however, if you or someone you know are interested let me know and I will scan and send you the logs. No Prop Strike.
~1300 SMOH
$8K each OBO
located at KSAC
serious inquiries only
RV-6a o-320 D1A w/ ported heads, CS prop.
Last edited by meyer228 : 05-18-2017 at 03:28 PM. Reason: Found out more information. :)
Old 05-20-2017, 07:49 PM
n82rb's Avatar
n82rb n82rb is offline
If these are out of a Comanche they are IO-320-B1A engines and require a dynafocal 2 mount and have rear induction sumps.
Bob burns
Rv-4 n82rb
Old 05-20-2017, 11:06 PM
bisquit bisquit is offline
Will they work on Rv 4. And what is preferred by 4 owners as engine of choice
RV 3 kit bought still in garage
RV 3 N3456B bought
25 yr VFD
Old 05-21-2017, 08:50 AM
n82rb's Avatar
I don't know if vans makes a d2 mount for the rv-4. Also the sump would need to be changes as there is not enough clearance for the rear induction on that engine. I know the engine can be changed to a d1 but I don't know the details of the process other than the mount lugs must be changed on the engine.
Bob. Burns
Rv-4 N82rb
Old 05-21-2017, 10:39 AM
cajunwings cajunwings is online now
Default Dynafocal 2 to 1 conversion
I had a IO-320 B1A crankcase converted from its original Dyna 2 configuration to Dyna 1. Engine was disassembled and Divco in Tulsa did the work for $250. The engine mounting ears get welded up then machined and drilled to Dynafocal 1 configuration. A bottom or forward inlet sump is needed to work on a RV.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 05-22-2017, 04:23 AM
Default Rv4
Thanks for the information
RV 3 N3456B bought
25 yr VFD
Old 05-22-2017, 08:29 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
I donít know why I havenít built one of these for years, maybe Vanís decided to stop offering them but I have built many type 2 Dyna mounts for RV-4 in the past and still could build them, seems if someone needed one we could talk to Vanís and work something out.
Russ McCutcheon
www.mccutcheonmetalfabricationaviation.com
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 05-22-2017, 07:43 PM
longline longline is offline
Default Comanche or Apache?
Conflicting information here, makes a difference.
Old 05-22-2017, 08:02 PM
n82rb's Avatar
The original post said IO-320' I don't think the apache ever had IO's installed.
Bob burns
Rv-4 N82rb
Old 05-22-2017, 09:18 PM
Bob burns
Rv-4 n82rb
Sorry, I miss labeled this post and tried to edit it but it didn't work. They are out of a 1965 Twin Apache and they are o-320.
