E. D. Eliot
Working on the skeleton of the left wing. Have all of the ribs clecoed into position.
There are a few evenly spaced 1/8th inch holes factory drilled into the spar between the first and second ribs that to me, have no function. That is, I can see thru the spar and these holes anchor nothing to the spar. I have closely reviewed the plans and clecoed on the bottom skins. The bottom skins fit perfectly so I'm 99% sure that I have the ribs mounted to the main spar correctly.
But, I'm concerned that I have missed something. Please advise - thanks in advance.
