Champ
Pulled my wheel pants to check brakes and tire pressures before an extended cross country and found this gouge and crack in the right main. The tire is a Vans supplied Air Hawk 5.00x5 that came with the kit about 17 years ago. Its got 140 hours and approximately 360 landings on it. All on paved runways. I run them at 36 psi.
1. I'm inclined to replace it before the next flight. What say you?
2. Is it best to replace both tires at the same time?
3. I've had zero problems with leakage so would it work to reuse the tubes?
