kevinh
Hi ya'll,
So my original Van's oil cooler (now for sale - PM me an offer if you want it) has worked fine for 300 hours. It was fine for cross country flying, but on hot days a series of loops oil temps and CHTs would get high enough I had to back off for a while (I'd let things cool down when CHTs reached 420).
I know an oil cooler is just for cooling oil, but a local RV friend said that he had the same problem until switching to the SW8406. I figured that I liked working on the airplane and for $600ish bucks it was a good experiment.
Wow! I swapped the oil coolers (after having to slightly rework the aft baffle). Now my CHTs and oil temps are 20-40 deg cooler for the same OAT and mission. I was never able to get the CHTs above 390 even after a bunch of loops.
I guess the SW has higher airflow resistance and more of that airflow is either doing useful work exchanging oil cooler heat or going through the cylinder fins.
I have an O360-A1A (ECI and superior parts from Aerosport Power).
Your mileage may vary, but so far I'm a happy camper.
PS: If you are building a plane that you will not use for acro and want a Van's oil cooler I've got one for sale. ;-)
