Go Back   VAF Forums > Main > Reviews
Old 10-27-2010, 01:17 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Yep, I'm headed to the HW store today to see what I could find. I was hoping a standard 1/4" AN washer would work, but its OD is 1/2.
Will update the thread if/when I find something. Thanks...
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 10-27-2010, 03:55 PM
Bevan Bevan is offline
Default No holes
I'm wondering if they would make attach hardware with no holes. Then drill our own to proper size.
Bevan
Old 10-28-2010, 09:56 AM
RV10Rob's Avatar
Couldn't find anything that would work perfectly, so I'm just going to make bushings from the 3/8" OD aluminum tube. The holes in the brackets are about 15/32", so not ideal, but should be good enough.
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 10-28-2010, 11:34 AM
Brantel's Avatar
Brantel Brantel is offline
Crow does not make these brackets, they buy them. They had a hard time finding a bracket just like we need at a reasonable price.
Bevan
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-28-2010, 11:45 AM
Kyleag04's Avatar
Kyleag04 Kyleag04 is offline
Default Crow Harnesses
I just got my Crow Harnesses last week. Great service, fast shipping, and exactly what I ordered.
As you all have noticed, Crow is shipping all RV harness with the longer end fittings now. On the crotch strap, at least, I have decided that I am going to drill a new 1/4" hole up from the existing 7/16" hole. Then I will cut off the existing hole leaving plenty of edge distance.
This will put the crotch strap in a much better position for ease of installation and will help reduce chafing of the belts against the bracket.
When I get the exact location of my this new hole, I will post it.
Kyle Schroeder
Emp & Wing - done
Fuselage - Upright Canoe
Old 10-28-2010, 06:43 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default So . . .
If I have a bunch of bushings made up for 1/4" bolts, people may be interested?
I'm going to do it for my own needs - but my local machinist could bang out a few more sets.
Rick 90432
Old 10-28-2010, 07:03 PM
RV10Rob's Avatar
Rick 90432
Absolutely. You'd have a monopoly on bushings with a 1/4" ID and 7/16" OD, apparently.
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 10-29-2010, 05:30 AM
rjcthree's Avatar
Default Hey
Could that be the key to my financial independance and the way out of the corporate rat race? Bahahaha!
I'll do the homework this weekend and see what my machinist thinks. I'm thinking aluminum. 6 per airplane, I'm thinking.
Rick 90432
Old 10-29-2010, 05:31 AM
jmitchell jmitchell is offline
Default Bushings
I would buy a set of bushings to make the Crow harnesses work.
Thanks.
Jeff Mitchell
RV-8 Flying.
Build log:
http://www.mykitlog.com/jmitchell
Old 10-29-2010, 09:46 AM
rjcthree's Avatar
Default I'm making up 12 sets
I'll give this a shot. I'm having a few sets of bushings made up - I have to confirm 6 or 8 per 2-seat RV, assuming crotch strap, not sure about single shoulder?
I'm going 6061t6, simple to fit, not intending to be a press fit. 1/4" hole.
I'll update this when I have more info (couple days).
Rick
