Go Back   VAF Forums > Main > Reviews
Old 10-01-2010, 01:06 PM
LR2001 LR2001 is offline
Default Contact?
Dan, Who did you speak with at Crow to get your harnesses (with the reducer bushings)?
I phoned them today and talked with Fred, but he had no idea what I was talking about: He said their long anchor hardware has a 7/16 hole, and they have no machined bushings to reduce it. Said I would have to machine my own.
Is there someone else I should talk to there?
Thanks!
Matt
Old 10-01-2010, 01:12 PM
Brantel's Avatar
Brantel Brantel is offline
You can also just drill a hole in the longer one up from the factory hole. There is plenty of room and edge distance.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-01-2010, 01:17 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I originally made bushings on my lathe for mine, but the larger brackets stuck out so far they were almost touching the seat backs. I ended up drilling holes and cutting the ends off. For the two in the back I used the smaller crow brackets and ground a tiny bit off of the clevis on the seat belt cables.
Andy Compton
RV-10 - N432AC (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
http://picasaweb.google.com/pilotandy/
Old 10-01-2010, 01:27 PM
Brantel's Avatar
Andy, looks like that bird is coming along!! Hope the DRDT-2 worked out good for you!
Old 10-01-2010, 02:32 PM
DanH's Avatar
DanH DanH is offline
I spoke with Don. No mention of bushings, but they were in the box.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-01-2010, 03:04 PM
Lionclaw's Avatar
Yep, the parts are now mostly in one big airplane-ish pile! The DRDT-2 was awesome. It's with another builder now, helping build a 3rd RV! "Big Blue" was very well made, and I liked the beefier box steel.
Andy Compton
Old 10-25-2010, 05:22 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Has anyone actually talked to someone at Crow about the bushings? I received my harnesses about a month ago, with no bushings. Today, I called and talked to someone (didn't get the name) that said they don't make the bushings.
Wouldn't be that difficult to make them myself, but I'd rather avoid it if possible.
Thanks...
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 10-25-2010, 06:41 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Crow
I wrote down everything Brantel had suggested. Talked to Fred himself. He said they include the longer brackets now.
They showed a week ago, look great but no bushings. Looked at it for awhile, read some of the forum suggestions and just decided to drill fresh holes to correct size. Worked great. The new hole you drill for the crotch strap is good as it allows you to position the strap so that it is not pinched in the crotch strap vans bracket. The two brackets for the over the shoulder will need new holes drilled too, and to fit properly a little grinder time. Will post a pic if I have time later.
Nice belts, good price.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dynon skyview with a/p. 800+ hrs in 6 yrs flying.
Osh 11,12,15,17. Sun N Fun 2013. Flew to Cali/up pacific to Washington/Vancouver/crossed the Rockies east across Canada. North to Red Deer Alberta and Moosonee Ontario East to Maritimes Canada. South east to Jekyll Isl on atlantic, Cedar Key and Key West too! 4 trips and 14 islands of the Bahamas too! Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 10-27-2010, 11:55 AM
RV10Rob's Avatar
I'd rather not add a hole in the bracket, which means I need to find something with an 1/4" ID and 7/16" OD. Any ideas?
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 10-27-2010, 12:20 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Lowes
Rob,
I would go to the hardware store and try to find a bushing the correct size or close. Also I think I read where someone used AN washers to fill the gap. I am watching this thread since I plan to get a Crow harness when time comes.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
Olympia, WA
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2017
