Go Back   VAF Forums > Model Specific > RV-4
Old 01-11-2017, 07:19 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default RV 4 Engine selection ?
I need to decide what engine for my 4 project. I am not a horsepower / ROC / Speed seeker. I am relatively anal about smoothness and am convinced a big engine loafing is more desirable than a small engine working harder to fly the same speed.SO, there are three options for me:
* 340 from stroke increase
* 340 from bore increase
* 360 pretty much stock with maybe 15lb weight penalty
Your comments from EXPERIENCE would be appreciated...Larry
Larry DeCamp
RV-3B flying
RV-4 fastback project in the shop
Clinton, IN
Old 01-11-2017, 09:13 PM
AX-O's Avatar
AX-O AX-O is offline
The 340 is not the smoothes motor and depending on the prop combination there are harmonic issues. Not sure how you came up with the 340 as being smooth compared to others. But i can tell you my 0-320 on my previous rv-4 was way smoother than my IOX-340 in my new rv-4. To the point that i thought something was wrong. Both engines/props were dynamically balanced.
I have had issues with the spinner bulkheads and the prop wearing on each other due to the vibrations. Craig Catto gave me some bevel (spelling?) washers and told me to keep a close eye on it because it is a major problem if it keeps happening. He then told me about the harmonic issues a certain rpms (from test data collected) and cautioned me to stay away from those at continuous rpm operations.
In 100 hrs i have had broken 3 exhaust hangers and found a crack on the exhaust flange on #4.
Hope that helps.
Axel
RV-4 fastback thread and Pics
West Coast Ravens
Supported by EarthX Batteries
VAF 2017 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 01-11-2017, 10:48 PM
Christopher Murphy Christopher Murphy is offline
Default Smooth
A 320 with a smooth wood prop on a light airframe makes a great airplane. The 320 is pretty bullet proof.
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 01-11-2017, 10:50 PM
ArlingtonRV ArlingtonRV is offline
I had a 160HP O-320 with a metal Sensenich prop in my -4. It was reasonably smooth, but could be better. I did not have it dynamically balanced. I ran a 3 blade Catto on it for a while and that was very smooth.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 01-12-2017, 12:39 AM
Jetj01 Jetj01 is offline
Default No question for me- Lyc O-360A1A
Hi Larry,
I have owned four -4s. The first three I bought flying and three had O-320s two with wood props (Sterba and Demuth) and one with a metal Sensenich. I finally built my own -4 after a venture with an RV-8, RV-6 and a Rocket. With those hours and experiences under my belt I went with an RV-4 with an O-360 A1A, carbureted, and Hartzell 74 inch Blended Airfoil. I've had it balanced and LOVE the combination. And now with my EMags it's even smoother. At cruise I run 2350 RPM which keeps the vibration and noise down and can routinely see 200+ mph at 8gph. Flying formation with my O-320 neighbors I can see 6-7 gph at 170-180 mph TAS. I do not fly 'hard' aerobatics in my -4, usually limited to 3-4 Gs and do not have an inverted system. With the energy my airplane maintains I can do a vertical maneuver (loop, Immelmann) from level flight and gain energy! I also LOVE the combination for formation flight and pattern energy control. I'd venture to say once you've gone constant speed in an RV, it's hard to go back to fixed. I used to fly my -4 800 miles a week from TX to KS and back and used to look forwArd to the flight (good seats help) and consider the -4 my perfect all around best airplane......for me. The O-360 'fits' well and gives you a 'no excuses' airplane when built for YOU! Enjoy the adventure!
Jj
Eagles Nest, TX
Built and FLYING RV-4 Fastback!
SOLD RV-6/RV-8/Rocket
Retired USAF, Current Boeing Driver
Dues paid ...thru 2017
Old 01-12-2017, 08:26 AM
Tomcat RV4 Tomcat RV4 is offline
I have RV 4 with STOCK rebuilt Subaru 2.5 Legacy ,with SDS control for fuel injection,ignition, (stošk) along with stock starter,alternator.I used 0-320 mt that came for RV and made own adapters from Suby to mount so a 0-320 could be reinstalled with standard mounts.we have our air worthiness and are currently taxi -testing.However hard to find calm days this time of year in Northeast for first flight.Using PSRU from Air Trikes in Canada,along with their 3 blade ground adjustable 3 blade prop.Using rad underneath,similar to Ross at SDS, my ductwork aluminum,his made neater with fiberglass..Give me e mail an would photos.Tom (have not had time to figure posting photos here)
Tomcat RV4
dues paid and worth every penny
Old 01-12-2017, 09:40 AM
WAM120RV WAM120RV is offline
Default Look at the UL power engine
O.320 with Sensenich FP on mine and TVs not bad.
However, as I will need another engine for my 9 I am considering a UL power engine. Much lighter than a lycosaurus, and more power, plus 6 cylinder which should make it smoother. One has just been fitted to a 4 in the states.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 01-12-2017, 12:14 PM
sblack sblack is offline
Originally Posted by Jetj01 View Post
Hi Larry,
I have owned four -4s. The first three I bought flying and three had O-320s two with wood props (Sterba and Demuth) and one with a metal Sensenich. I finally built my own -4 after a venture with an RV-8, RV-6 and a Rocket. With those hours and experiences under my belt I went with an RV-4 with an O-360 A1A, carbureted, and Hartzell 74 inch Blended Airfoil. ......he O-360 'fits' well and gives you a 'no excuses' airplane when built for YOU! Enjoy the adventure!
I have heard that having a CS on a -4 moves the CG quite far forward, enough to increase the pitch forces so that you no longer have the nice light handling. But you seem to be very happy. Do you notice a big difference between the wood prop airplanes and the 360/CS in terms of pitch forces? Or do you always fly with a fat guy in the back seat?
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 01-12-2017, 12:36 PM
springer springer is offline
O-360-A1A with Warnke FP on my -4. 1 mag 1 LSE. Very smooth and significantly out performed my O-320 -4 flying partner.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 01-12-2017, 05:33 PM
Michael Henning Michael Henning is offline
IO-360A1A pumped
Up to 200 HP. With the whirlwind prop, my empty weight cg is within 1/2" of where Van recommends. So I still get the light handling, with the added vertical performance. Plus, I had the prop balanced so it is turbine smooth with the 3 blades.
Mike
RV-4 #2750
N654ML
IO-360 200HP
WW150C Prop
1018 lbs
Flying
