Old 01-11-2017, 11:59 AM
pastranafan5 pastranafan5 is offline
Default Anti splat aero
What are your favorite products from this company and why? I'm going to buy some stuff and want to know what all I should get.
Old 01-11-2017, 12:03 PM
Auburntsts's Avatar
Well I have his prop wrench and the ultimate gust lock and I give them both a big thumbs up.
Edit: Forgot I have the oil filter wrench too!
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 01-11-2017, 12:20 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Great stuff
Oil Wrench
Oil Separator
Crank Case Vacuum kit
Prop Wrench
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
Olympia, WA
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2017
Old 01-11-2017, 12:41 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Default I have most of them
I have installed many of the products from AntiSplat on my 9A. My favorite is the wheel mods where they press in sealed bearings. Next up would probably be the Almost-a-14 mod and the Air/Oil separator. Nose job is good too but hopefully I will never need to test it. I also installed the vacuum adapter for the air\oil adapter, the magnetic oil plug, Jack points, and the gust lock.
I have nothing but good things to say about the company and the support I got when I called them with questions/concerns.
Darin
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Wings - Flaps/Ailerons
www.DarinAnderson.com
2018 donation sent!
Old 01-11-2017, 01:02 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Good products - good people
In order of purchase/install:
Nose job(peace of mind for A model)
Nose wheel bearings(helps eliminate shimmy)
air/oil separator with vacuum(clean belly and cures annoying tiny oil leaks)
gust lock(keeps getting better)
main wheel bearings(no more grease + shimmy elimination)
Good products and good people to deal with.
John Morgensen
RV-9A N946PM 500+ hours since 2013
Nevada/Arizona
Old 01-11-2017, 01:56 PM
Raymo's Avatar
Raymo Raymo is offline
Nose Job 2
Skid plate
Nose wheel bearing mod
Vertical stab attach doubler
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 01-11-2017, 02:15 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Prop Wrench
Oil filter wrench (wouldn't buy again - clamp style from Napa works just as well)
Gust Lock - GREAT product!
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
First Flight - April 12, 2015
Construction Log
Old 01-11-2017, 03:48 PM
Default VS bracket mod
Recently installed VS bracket mod.
Old 01-11-2017, 04:31 PM
that's secure but I didn't see any cracks before. when I look at this area my heart says yes but my mind says why? I hate it when that happens.
Anti-spat products:
1. nose job
2. prop wrench
3. oil wrench
4. gust lock
[/quote]
Old 01-11-2017, 04:36 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Nose job
Skid plate
Oil separator
Almost 14 - not yet installed but imminent
Good quality products all, plus you get a cap which makes you look like a farmer.
Nigel
RV9A-N113SQ
52F
