Old 01-09-2017, 12:14 AM
ron sterba ron sterba is offline
Question Access door on wheelpants of RV9A,where2Buy
Getting ready to build my wheels pants, struts for my RV9A and have had a couple RV builders wish they would have installed little doors to access the valve stems. So I decided I will installed them. Anyone know where I can purchase the round button type latch or something you could recommend or size of the door?
Ron in Oregon RV9A
Old 01-09-2017, 06:03 AM
http://www.mscdirect.com/industrialt...hole-plug.html
These come in steel and plastic. You can paint 'em. Anywhere around a 1" size is fine.
You can find them at your local Home Depot or Lowes too.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-09-2017, 07:53 AM
GatorJim's Avatar
GatorJim GatorJim is offline
This Camloc latch may be what you are thinking about:
https://www.aircraftspruce.com/catal...snapart110.php
Jim Heekin
Orlando, FL
RV-8 QB
Last edited by scrollF4 : 01-12-2017 at 04:24 AM. Reason: Moderator Note: Removed EBay ad
Old 01-09-2017, 10:15 AM
bruceh's Avatar
bruceh bruceh is offline
From experience with the cam lock ones, they just aren't big enough to make filling the tube easy. If I was to do it again, I would make a much larger fiberglass cover that could be held in place with a couple of screws. Make them big enough to get your fingers in to unscrew the valve stem cap. Similar to what I did on the cowling to cover the hinge pins. Just lay up some fiberglass over the spot, use the cured fiberglass as a cover (cut to a sufficient size shape), then cut a hole in the pants, and finally tape it in place and do some fiberglass build up underneath to make a flange for the cover to lay on. A couple of nutplates in the flange to hole the cover. Probably more work this way, but definitely cheaper than the metal cam lock covers!
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 01-09-2017, 11:14 AM
Pat Stewart Pat Stewart is offline
This method works great and is the easiest to install. Just make sure you don't leave the valve stem cap on and don't ask me how I know this.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 01-09-2017, 11:42 AM
You can use a piece of clear plastic tubing with an inside diameter just smaller than the cap to remove or reinstall the cap through the hole.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-12-2017, 12:42 AM
Now I like the tubing cap removal idea Kyle. Yep that 1" cap idea looks the easiest. Jim that's the item I was looking for. Now iam going to look at the work at installing the door or hole - n - cap style. Bruce iam now thinking do I need all that extra work for the camloc when your idea with a couple of nut plates and a plate sounds good. I'll have to sleep on this one a little longer.
Ron in Oregon RV9A N421HJ. MORE-FUN THAN A Honda Jet!
Old 01-12-2017, 12:46 AM
Question Automatic tire pressure readings
Has the electronic tire pressure sensors for automobiles ever been installed in General Aviation tires. What a great idea for our RVs.
