Old 01-11-2017, 09:16 PM
yankee-flyer yankee-flyer is offline
Default Rotax engine problem
here's one for the knowledgeable Rotax guys. At the 400-hour inspection, both carbs were removed, cleaned,and new gaskets fitted by an A&E who's had thew long Rotax training course. He also set the floats using a new tool from Rotax. Ever since, when I do the normal cold start sequence (worked fine before) the engine will start on full choke, but after a few seconds it stumbles badly, like sparl plus misfiring and RPM drops. Going to half choke immediately helps for a half-minute, then the RPMs drop WAY into the yellow arc. I've got to go to no choke at all by about 30 seconds in order to keep in running, even with OAT at 30 deg and no temperature movement on any of the displays.
I don't see how it's possible to "over choke" the engine-- I'm thinking mixture is too rich.
Any thoughts at all? Thanks.
Wayne 120241/143WM, 420 hours.
Old 01-12-2017, 01:59 AM
You might consider asking this question in the Rotax Forum http://www.rotax-owner.com/en/rotax-...ical-questions
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 320
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 01-12-2017, 03:16 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I have never used the shoke for more than approximately 10 sec.
PH-BZT
MyKitlog
Picasa pictures
Old 01-12-2017, 03:44 AM
In cold weather I bleed the choke (enrichment) off in steps as the engine warms. If choke is removed too quickly during cold engine start the engine will run rough.
Hinckley, Ohio
Old 01-12-2017, 05:53 AM
h&jeuropa h&jeuropa is offline
Wayne,
It is very easy to assemble the choke assembly backwards. You might want to have the A & E take them apart again and be sure they are correct. Have a look at chapter 3.3.11 of the heavy maintenance manual for guidance.
Jim Butcher
Europa XS, Rotax 914 - 800 hrs
Old 01-12-2017, 06:45 AM
JBPILOT JBPILOT is offline
Default Another question - -
Were the carbs re-sync'd after reinstalled ? When cold do the EGT's match fairly closely ? When warm, do they match fairly closely ? Gives you a very good idea of how well they are sync'd.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-10-17 )
Old 01-12-2017, 07:58 AM
Default Yes
Carbs were re-synched, EGTs and CNTs match well, and engine operation is good once it's warmed up.
POH AND recent Rotax Service bulletin call for full choke at start, then ease off to 1/2" and maintain that until the engine is "warm". That has worked fine for6 years and 400 hours.
Wayne
Old 01-12-2017, 09:48 AM
Default Wayne - -
Then I would check to see if the Enrichener 'disc' is in correct position. There is a center punch mark on the external portion of the shaft. It should be toward the cable hookup end of the arm. Easy to check.
John Bender
Old 01-12-2017, 08:35 PM
I've always been reluctant to do much to the carburetor other than inspecting the bowls and replacing the diaphragms at 5 years. It seems that if they are working well it is best to leave them alone.. just my opinion.
Old 01-13-2017, 06:24 AM
tomkk's Avatar
tomkk tomkk is offline
I agree. I disassembled mine for the 200 hr inspection and they were like new. They were clean, gaskets and O-rings in great shape, etc. Not only did I pretty much waste my time, I took the risk of messing something up - I didn't
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
