Old 04-11-2019, 09:10 AM
Ottoman Ottoman is offline
Default rubber grommets
I'm looking for grommets that will fit the hole in the side skin for the fuel line.
gap width is 1"
gap thickness is 1/4"
hole is 3/8"
Does anyone know a company that sells them?
I ran across a thread about these grommets maybe a year ago but can not find it again.
John Aiton
Old 04-11-2019, 09:28 AM
https://www.mcmaster.com/grommets
Old 04-11-2019, 11:13 AM
bruceh's Avatar
bruceh bruceh is offline
Be sure to order extras if you have an A model. The same size will fit in the gear weldments to keep the fuel lines that weave through there from rubbing anything.
On the outside of the fuselage. Fuel lines and vent lines.
On the inside passing through the gear weldment.
I think I sourced these from Aircraft Spruce. Look for AN931 elastic grommets.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2019 VAF donator
EAA Tech Counselor
Old 04-11-2019, 11:51 AM
Thanks for that web site, I ordered what I needed, had to order 10 minimum.
I should be running my fuel lines in the next couple weeks so the pics helped.I didn't know the line went through the gear mount.
John
7A
Old 04-11-2019, 12:14 PM
Larco Larco is offline
How about this at Vans. There should have been some in the kit too. https://shop.vansaircraft.com/cgi-bi...roduct=bushing
Old 04-11-2019, 08:47 PM
jcarne's Avatar
jcarne jcarne is offline
I used these, they fit perfectly and went over both pieces of metal.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 04-11-2019, 09:06 PM
Robin8er Robin8er is offline
I think I found some at home depot.
RV-8
N695RA Reserved
Emp and Wings done, working on Fuselage.
Born to fly, forced to work
