Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Autopilots
Old 05-15-2017, 04:20 PM
Raymo's Avatar
Raymo Raymo is offline
My roll servo went out prior to first flight and I had to do the same thing. I rang out the wires and knew they were good but Dynon wanted me to do the swap.
To make things easier, I made another servo harness so I could just plug the pitch servo wiring into the roll servo. Same problem so it went in for repair and came back working like new.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 05-15-2017, 08:33 PM
Aggie78 Aggie78 is offline
Default Well, I was hoping for something sexy...
Like a failed pitch servo I could point at and go "A ha!" to.
Not to be.
Moving the pitch servo over the roll servo and hooking it up there and the pitch servo worked like a champ.
So...Not a servo issue, it's an accursed, mundane wiring issue. Bah!!
Tomorrow I do the deep dive behind/under the panel to find the offending connector/wire harness on that end.
Hopefully, it will just be the connector and not a cut wire under the floor somewhere.
Posting all of this for future Dynon troubleshooters....
Rob Schroer
RV-7/N75WV
YIO-360-M1B
T67-Hicks Airport, Texas
Old 07-01-2018, 09:20 AM
Logan Logan is offline
Default Update?
Hi, Rob. Did you find a bad connection to this issue? I am facing same issue.
I had to swap pins in the Molex that powered the pitch servo and pitch trim to fix a reverse pitch trim issue. When I plugged it back in, I lost both AP servos. I am sure I must have messed something up in the molex, as it was the ONLY think I touched, but can't for the life of me get it back to working. Hoping for a new aha moment for something else to look at.
Logan
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
Old 07-01-2018, 02:29 PM
Duh. Circuit breaker had tripped. As I am using a electronic circuit breaker system, I had to check the right page on the EFIS to see and reset it.
Posting to remind myself and others to start with simple checks first!
Logan Dent
RV-14A Complete!
