One change I made was to open holes in the flooring large enough for a socket and extension. That way I can pull the cap plugs out and adjust tension on the block without removing the floor.
Bret,
I believe there are a couple of diffrent ways done in the past.
Either like the levator trim or a seperate tab hanging off the back.
http://www.vansairforce.com/community/showthread.php?t=64641
http://www.vansairforce.net/buildermods.htm
And yes the springs are pre-loaded per the instructions. It was this pre-load that I did not like the feel of. I need to reconnect mine but play with different tensions.
Bret,
