Old Blue protective covering
dave4754
I have checked the archives and found that diesel oil or kerosene will take off the old blue protective covering from my wings. this stuff has been on for ten years!
Has anyone tried this? Did it work?
I will paint mine, those that painted did you have to scuff, sand all surfaces?
Get a broomstick longer than your covered piece and start in a corner or end and wrap the plastic around the stick and keep working it off by rolling the stick across the piece.
I had no problem peeling off the blue stuff. I used a long PVC pipe to remove it by rolling it onto the pipe. However, the clear stuff on the plexiglass canopy was tenacious and needed some persuasion.
