Anti Seize EGT Probes?
Lynnb
I was putting the exhaust on last night and using Nickle Anti Seize on the studs and slip joints. It got me thinking, should a little bit be placed on the butt end of the egt probe before it is fully inserted, since I have read that at some point these will probably burn out and need replacing, seemed like a little insurance for clean removal. Now I'm not talking about covering the whole probe, just the last little bit.
Thoughts?
Lynn
I put anti-seize on my CHT probe threads, but have not ever done that on EGT probes. I've never had an issue removing EGT probes, and I've done many, so see no need to use AS on these.
