Hairball192
Member
Hi all,
I'm building an RV-12 ULS... the fuel tank is complete but NOT installed yet. I'm in the process of doing SB 13-12-19 for the tank attach brackets and Mod 37B for the fuel vent.
Mod 37A eliminates the sight gauge and is only required if the sight gauge is leaking. Since mine hasn't held fuel yet I don't know if it'll leak.
My question to the group is advice on whether or not I should just go ahead and do 37A to eliminate the sight gauge preemptively or if I should only do it down the line if mine leaks. Sorry I couldn't attach the pdf's so you'd be able to see it more precisely.
Harry
Harry
