Thank you. Help searching the correct name.
I left mine out on a rebuild, seem wasteful to spend a couple hundred bucks on something that I wasn?t going to use, but I was getting a lot of oil out the crankcase breather, so to avoid removing the rear case and installing the tach shaft I put an anti splat oil separator on the crankcase vent and that solved the problem, I still spent the money anyway!
Keith Rhea RV7
2019 dues paid
