I have one E-Mag and one Slick Mag on my RV10. They have sent me 2 other E-mags to test. All of them including mine have the minimum set at 22 degrees BTDC. During climb my CHT's are around 400 degrees (they normally run around 375). Since I have the IO-540, the minimum should be set at 25 degrees. I have advanced the timing setup about 3 flywheel teeth which will place the minimum at 25 degrees. During climb my CHT's are back down at 375 degrees. At 5500' setting lean of peak, the CHT's go down. If I turn off the Slick mag I can hear the engine occasionally miss firing but no indication on my engine monitor. If I switch to "fixed" mode the miss firing goes away. Anyone else been having problems with the 6 cylinder E-Mag?
