Old 02-13-2018, 09:11 AM
tyconnell tyconnell is offline
Default R-00001
Does anyone know what this is?
I'm assuming it's a rudder part, given the "R-" nomenclature, and it came with the empennage. I believe it was in the "plates and gussets" bag (don't have the bag number / inventory list in front of me).
I've re-read the construction manual (pp. 6-3 - 6-5), and studied the drawing (DWG 7), and I just don't see it.
I'm past the rudder, and I'm a little concerned I missed something.
Ty Connell
Atlanta, GA
EAA Chapter 690
VAF dues paid monthly
ty.connell@gmail.com
N997TL reserved
RV-9(A?) empennage in progress
Old 02-13-2018, 09:24 AM
Default Not me too
I don't recall that in my kit. But I learned doing the wings, save these little jewels, you might need them later. I am finishing up the wings and found the templates to drill the tank attach brackets.... about 6 months too late.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 02-13-2018, 09:39 AM
wirejock's Avatar
wirejock wirejock is offline
Default Mystery part
Check the inventory. It should have a description for the part.
Call Vans and ask. It may be important.
From the part number, it looks like a newer addition.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 02-13-2018, 09:52 AM
airguy's Avatar
airguy airguy is offline
Obviously punched for a couple nutplates, and bolts instead of screws by the look of it. That suggests a doubler for a hinge attachment, or tie-down attachment perhaps? My late-2007 era empennage kit did not contain this part.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-13-2018, 09:55 AM
Mike S Mike S is online now
The holes appear to be for a nutplate.
Possible a reinforcement for the fiberglass parts, or lead counterweight???
Old 02-13-2018, 10:07 AM
Ron B. Ron B. is offline
Not saying but there were a few parts left over in my kit that do not get used.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 02-13-2018, 10:17 AM
A good suggestion, I'll have to look at it later.
That said, it's also not on the list. Maybe not everything is?
Ty Connell
Atlanta, GA
EAA Chapter 690
N997TL reserved
Old 02-13-2018, 11:03 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Check the hole spacing, it could be a "two nutplate holder" that replaces the two nuts retaining the rudder lead counterweight.
Weren't some folks having trouble with these nuts coming loose as the lead squished a bit and then had no access to tighten them after assembly?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-13-2018, 11:38 AM
That is what I was thinking of---
Old 02-13-2018, 12:06 PM
ERushing's Avatar
ERushing ERushing is offline
Gil hit the nail on the head. That is a nutplate strip used to attach the rudder counterweight to the Rudder Tip Rib.
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
