Gents,
I need your assistance. I installed the four studs on on the governor adapter without any issue (used some grease) using the double nut technique.
I had planned to use the VA-153 bracket (mounts to the back of the governor) on my PCU-5000X governor but the VA-153 doesn't work well with the PCU. Van doesn't sell the VA-183 any longer so I made my own version. The VA-183 mounts to the governor mounting flange and uses two of the studs.
Now I need to back out two of the studs to accommodate the VA-183 and the extra washer needed between the bracket and the governor mounting flange.
I tried the double nut trick but the nuts turned on the stud and the stud didn't rotate.
Any thoughts on how to back these studs out?
Hope I don't need to use a vice grip and replace the studs.
