Hi,
i have searching the forums to get info. about where to install the ELT antenna in the RV-8. It seems there is not a good place.
In the last Sun & Fun there was a Kannad ELT with internal GPS and 406 Mhz. antennas . The weight is 755g and the dimensions 140mm x 98mm x 86.4mm.You can get more information in
http://www.kannadaviation.com/index.php/ga-fixed-wing
I?m thinking about installing the ELT in the upper side of the firewall. the same place many builders and Van?s in the RV-12 install the GPS antennas.
I appreciate comments about this location.
Jose del Peso
RV-8 (#80971)
Electrical
Jose del Peso
RV-8 (#80971)
Electrical
