Countersinking F/G Wing Tips
jimbo
Patron
I went to countersink the #6 holes in the wing tip edge to accept the dimpled edge of wing skin for attachment with #6 screws.
The white gel coat cracks/splinters off well outside of the circumference of the countersink. Is there a trick to get good clean countersink for these holes? Funny that I did not have this problem when countersinking for my platenut attach rivets but these #6 holes are little ragged around the edge.
Jim
RV9A
I just did my R. wing tip last week and it did the same thing, I just took the CS bit and turned by hand a couple of turns. using # 8 screw
Expensive But....
AveryTool sells Permagrit countersink bits in various sizes for $22 each. You can use a regular CS bit on raw Epoxy like the cowl, but not the Polyester Gelcoated Tips as you discovered.
