FI Hot Start Question ?
Larry DeCamp
I am putting an AFP FM-150 system on my 360. Don says the latest system does not need a purge valve and if properly installed, there are no idle issues. I read that insulation on lines FWF dont always solve problems. My question is: why wouldnt taxing around to cool the fuel lines after a heat soak for $100 hamburger or 100LL solve the problem without a purge valve/return line ?
The purge valve is installed between the servo and the flow divider, so it can’t purge fuel in the injection lines as they are downstream of the valve.
Tim Andres
The heat soak happens when you shut down the engine and let all of the exhaust and engine heat just sit idle in the cowl and heat everything up. A long taxi would help to cool the engine, possibly, but usually you land with a fairly cool engine. Lot es of engines heat up while taxiing because there is so little airflow.
Though even at best, the Bendix style FI is not going to start or idle like a modern car, it's hard to call the behavior of a nominally performing system a "problem". You will learn how to reliably start the engine regardless of heat soak, and you will also learn to accept the sometimes chugging and spitting as normal ops. It's not unsafe, it's not a problem, and it clears up as soon as you flush the system with fuel on takeoff.
Thanks for responding
I guess I was thinking of Toolbuilders solution to move some air over the injector delivery tubes in the plenum until it runs safely on the ground. Apparently I need to go to Don's seminar and learn how to avoid the transient rough idle condition since Don says a properly installed system won't do that.:confused:
Larry,
I had the typical FI issues with my IO-360 - engine coughing on the ground while taxing, in the pattern occasional roughness when coming in for a landing, etc.. I added a second layer of fire-sleeve over my fuel lines, and voila! All my issues went away. The engine runs great on the ground and in the air now.
This doesn't cure the hot-start issue - that comes with technique, which isn't a big deal once you understand what's going on with the Lycoming engine pump :)
Before:
After:
Thanks much Mike
I thought folks were having trouble with vapor in the small lines after the flow divider. Obviously your solution works, Thanks...Larry
Yes, the injector lines are a big part of the behavior, but understanding that is a big step toward managing it too. Airflow and fuel flow make the behavior go away, while high heat and low flow will bring it back. For example, you can "cure" the behavior with a runup (lots of fuel movement), but it will come back with a long wait at the end of runway.
Larry,
I thought along those same lines at first. My gut solution was to somehow insulate the stainless steel fuel lines from the fuel-flow divider to the injector. My primary concern with this was what adverse change could this make? My two fears were vibration with the stainless lines insulated and premature failure. My other concern was most of the times these lines being uninsulated were helping you - the cooling air would hit them first before it went through the engine!
My next thought was how else to make the fuel as cool as possible. That's when I had the idea for the second set of firesleeve. No negative safety issues with extra firesleeve, and easy to install. It will also do a better job of keeping the heat radiating off the engine from affecting the fuel temps. I was amazed at how a simple mod had such a profound change in the engine performance when hot!
The last thing I did was add a fuel-pump cooling shroud when I changed my fuel pump late last year. So far I haven't noticed any perceivable changes, but I also haven't flown it in the summer heat yet. I didn't add the shroud for any particular reason - just while the pump was being swapped out, it was a convenient time to install one.
Best of luck, and feel free to reach out to me with any questions.
Where is Dan Horton ?
Dan,
If the small lines are not the problem, what is the most effective insulator for pump to flow divider ? Double fire sleeve solves problems. What are other wrap options, fiberfrax and silicone tape or ???
