Cbull
I've taken so many ideas from this forum but really haven't given back. So here goes:
I think this only relates to RV-10's, why I'm posting here. I don't really know what builders do for the junction where the windows meet the fiberglass on the inside. Here is my solution, sorry if its been done before.
For this example I used 1/4" deep #8507K14 rubber edge trim from McMaster Carr. I basically made a little jig to cut one side off of the edge trim. To cut the trim I generously applied WD-40 to the trim as I pull it through the cutter. 20' of window trim in 2 minutes, perfectly cut.
I used the 3M instant adhesive in the pic below and installed about 3" at a time. The super glue is very expensive, $30 for that little bottle, but wow does it hold. I haven't even put a dent in it with almost all my trim installed.
A picture is worth a thousand words, so here are roughly 7000 words:
Inside of window....
Outside looking in...
Hope this finds someone who needed it
Cory Bull
Cory Bull
