I'm at the point of wiring the Nav/Strobe from a single set of wires coming off the VP-X to the three sets needed to go to wingtips & tail. There are two questions here. First, what is the best way to do the interconnect? I thought to just use Molex type connectors and jumper the pins from the VP-X to make the connections. Another idea is to use a terminal block. I am curious if anyone has a better idea. The second question is where to make the cross over. Could be behind the panel but lots of wires there already. Maybe cross just in front of the rear seats where the torque tube for flaps goes across? Going to be a similar problem for L/R landing and taxi lights.
